Steve B.
#1 Posted : Friday, June 13, 2008 3:26:13 AM(UTC)
Steve B.
Went turn on the stove and slected bake. Nothng happened. all other function work including broil,cleaning, timmers, ect. What could be worng?
#2 Posted : Friday, June 13, 2008 4:54:39 PM(UTC)
Hi Steve,
Most likely the problem is a bad bake igniter (#28 on the break down diagram).
- The part number for the bake igniter is AP2014008
Here are the break down diagrams for the GE range Model JGBP86WEA2WW
Steve B.
#3 Posted : Saturday, June 14, 2008 9:41:05 AM(UTC)
Steve B.
Thanks Gene, The problem is that when I touch bake on the key pad nothing happens. No beep nothing. If I push say broil it will beep and and flash Hi/LO, as well as all the other functions.Two monts ago I replaced the igniter, when that went bad I pushed the bake on the key-pad it beeped and the temp display showed 100 degrees but the it never turned on. Since I replaced it it has been working fine, till now. I have gone as far as replacing the control unit with no luck. I was thinking the only thing left is the key-pad (which is expensive) any thoughts? thanks again
#4 Posted : Monday, June 16, 2008 3:06:59 PM(UTC)
Hi Steve,
You are right, the key panel has to be replaced to solve this problem and it is expensive.
- The part number for the key panel is AP2035214
Steve B.
#5 Posted : Wednesday, June 18, 2008 4:27:56 PM(UTC)
Steve B.
Hi Steve,
Gere,
Replaced the key panel and we are cooking (baking) with gas. Thanks much for your time and advice.
~Steve B.
#6 Posted : Wednesday, June 18, 2008 5:02:09 PM(UTC)
Hi Steve,
I'm glad you were able to fix it.
