ikemon57
#1 Posted : Monday, June 16, 2008 4:38:40 AM(UTC)
ikemon57
the ice maker won't stop working. pumps out ice continuosly unless water supply is turned off. on/off switch inside freezer need replaced? has a little "electric eye" looking thing right below it. I've had to unfreeze lines before because of lack of ice, but never had one spazzing like this.
#2 Posted : Monday, June 16, 2008 7:34:40 PM(UTC)
If you are not able to turn the ice maker "off" manually and/or it does not turn itself "off" automatically when the ice bin is full of ice then the optic PC boards (emitter & receiver) have to be replaced. They are located on both sides of the freezer liner.
- The part number for the PC boards kit is AP3137510
