2 Pages12>
DOR122468@YAHOO.COM
#1 Posted : Friday, June 13, 2008 4:11:33 AM(UTC)
DOR122468@YAHOO.COM
I have a kenmore washer ( not sure how old) but it no longer spins. I was told I needed a coupling, which I bought. However, I cannot figure out how to install it. I tipped the machine on its side to access the bottom. The coupling is wedged between, what I think is the motor and a metal covering, which may be the transmission. I am not sure how to remove the motor ( there doesnt seem to be any bolts). Do I have to remove the metal piece? I am a single mom and cannot afford to pay a repairman, so I am determined to do this myself. Any help would be greatly appreciated. Thank you!
#2 Posted : Friday, June 13, 2008 4:58:11 PM(UTC)
Before we proceed with the coupling replacement I need you to answer on these questions:
Did it agitate?
Did it drain?
DOR122468@YAHOO.COM
#3 Posted : Saturday, June 14, 2008 10:08:58 AM(UTC)
DOR122468@YAHOO.COM
Hi Yes it did agitate and drain.
#4 Posted : Sunday, June 15, 2008 3:03:23 AM(UTC)
You probably have a bad clutch. Will need to pull tranny to change.
Tgarvey
#5 Posted : Thursday, October 2, 2008 6:33:04 PM(UTC)
Tgarvey
My first problem began when my motor coupler broke and I received a replacement (newly designed with metal inserts on each side of the plastic pieces of the coupler). I replaced the couple and did a test run with no clothes and all the cycles completed successfully. I then put just a few clothes into the drum and tried this again......no go. The machine will agitate fine but when it begins the spin cycle, I can hear the relay clicking trying to engage the motor to spin the tub over and over again quickly then just stops. The tub does begin to spin for about 3 seconds then just stops.
I read through some of your other forums and I unfortunately did pick the transmission up the shaft a couple times. I can spin the coupler and see the motor and transmission shaft turn. Should I focus on the tub now?
Any suggestions?
Todd-
#6 Posted : Thursday, October 2, 2008 6:39:43 PM(UTC)
Hi Todd,
What is the complete model number of the washer?
Tgarvey
#7 Posted : Thursday, October 2, 2008 7:35:19 PM(UTC)
Tgarvey
Hey Gene, I don't have the exact data that you are asking for. All I know is that its a Kenmore 90 series Super Capacity Plus with the Quiet Pack III and it was bought new in 1998 from Sears. I just pulled the control pannel and see that the manufacturer left the wire diagram but it doesn't come out and say any particular model number...all I see on wire diagram is part no: 3953250
Not sure if this helps.
Todd-
#8 Posted : Friday, October 3, 2008 11:42:08 AM(UTC)
Hi Todd,
Usually the name plate with model number is under the lid.
Tgarvey
#9 Posted : Friday, October 3, 2008 6:35:03 PM(UTC)
Tgarvey
Gene,
Here is the model number: 110.20902990
Type: III
Tgarvey
#10 Posted : Friday, October 3, 2008 8:24:07 PM(UTC)
Tgarvey
Gene,
I was eager to tear into the washer again to find out what could be causing the problem so I basically stripped the washer down to just the tub and the support frame. I was careful to note where everything goes so going back together will not be an issue. However, I took a closer look and the transmission and the splined shaft and noticed that when I stick the shaft directly upward there is play left and right and I fairly certain there shouldn't be any. Would you agree? Also, with all the components removed, it still feels like the tub is not easy to spin. I guess I'll need to go test out how easy it is to spin a new unit from the store. Any suggestions would be helpful. Please respond.
Todd-
Guest (9)
Kenmore washer wont spin . spins only when switch is turned to spin.. (Washer Repair)
by smieri6 7/18/2013 8:39:38 PM(UTC)
Kenmore washer wont spin?? (Washer Repair)
by ravenr106 4/19/2012 10:14:38 AM(UTC)
kenmore washer wont spin and keps on filling water (Washer Repair)
by elbebe2525 1/10/2011 8:01:05 AM(UTC)
kenmore washer wont spin (Washer Repair)
by black hemi 10/18/2010 4:45:35 PM(UTC)
Kenmore Washer Wont Spin (Washer Repair)
by racr 10/2/2010 5:10:07 AM(UTC)
Old kenmore washer wont spin (Washer Repair)
by bberinger1 2/23/2009 9:35:51 AM(UTC)
2 Pages12>
