Hi - I watched the washer as it ran through a cycle, let it fill. When it goes into the wash cycle, both the agitator and drum kind of lock up. They look like they want to move for maybe a quarter of a second, then lock right up and the electrical sound of something wanting to run and not being able to is pretty loud.
It fills, drains and spins fine.
Remove the washer front panel. Check if the transmission pulley can be moved CW. If not, the transmission is locked and has to be replaced. - The transmission Part number: AP3892125
Hi Gene - Thanks for the answer. Yeah, I can turn the pulley counterclockwise, but not clockwise.
Bummer, a new transmission. Well, thanks again.
Is that a really hard thing to replace, I've never taken a washer apart before. I see you sell the transmission, is there a book also to show how to replace it, or should I just get a guy in to do it?
This job is not very simple and if you do not feel comfortable to do it yourself, it's better to hire a pro.
Whirlpool LA5700XTN0 won't agitate
(Washer Repair)
by Kyou
6/2/2024 5:13:20 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise
(Washer Repair)
by deepdiver359
5/21/2024 8:09:21 PM(UTC)
Whirlpool Mod# LSQ9200KQ0 washer won't agitate or spin
(Washer Repair)
by Guest
5/13/2023 11:34:56 AM(UTC)
Maytag washer spins but won't agitate
(Washer Repair)
by salconflu
4/27/2022 6:06:43 PM(UTC)
maytag washer mvwc465hw3 won't agitate
(Washer Repair)
by Guest
11/22/2021 2:54:31 PM(UTC)
Washer won't agitate or spin out.
(Washer Repair)
by tracibailey
1/11/2019 8:43:20 AM(UTC)
Washer won't agitate, spin, drain, but motor runs
(Washer Repair)
by dmbailey0321
6/26/2018 11:36:55 AM(UTC)
LAT2500AAE will spin,rinse,and drain but won't agitate
(Washer Repair)
by jlh72
1/18/2018 5:39:10 PM(UTC)
Kitchen Aid Washer Won't agitate or spin
(Washer Repair)
by M Yaworski
7/18/2017 7:00:37 AM(UTC)
Washing machine won't agitate, will spin though
(Washer Repair)
by Freddy76
7/17/2017 4:05:56 PM(UTC)
Kenmore 110-92573200 won't agitate, but spins and advances
(Washer Repair)
by LallyCollins
3/5/2017 9:44:00 AM(UTC)
Whirlpool Washer Won't Agitate/Spin
(Washer Repair)
by Shazaam
9/1/2016 2:47:46 PM(UTC)
Whrilpool Cabrio won't agitate
(Washer Repair)
by Harvey E.
7/27/2016 11:58:40 AM(UTC)
GE Washer fills & drains, but won't agitate or spin
(Washer Repair)
by bonerjamz03
1/10/2016 6:17:17 PM(UTC)
Washing machine won't agitate, drain, etc.
(Washer Repair)
by rhinkley
12/17/2015 2:44:46 AM(UTC)
