3 Pages<123
#21 Posted : Thursday, July 22, 2010 12:42:38 PM(UTC)
Originally Posted by: JERRY314 Go to Quoted Post
ICEMAKEWR MODEL # IS wr30x10014, from what i'v e found this model has been replaced, mine has a 4 pin rectangular plug where most of the new ones have a round plug. Someone has suggested that i replace it with a Frigidare icemaker because they are more dependable. we don't have a lot of funds right now so i didn't want to buy a lot of parts that i may not need. the fridge is a GE Profile Arctic mod. PSS27NHMDWW purchased about 5-6 years ago.
Jerry,
What was the original problem?
JERRY314
#22 Posted : Thursday, July 22, 2010 1:31:16 PM(UTC)
JERRY314
seems that the ice won't dump after it freezes and it doesn't seem to have enough water in the tray. I don't see any water adjustment inside the icemaker since it has a circuit board inside. So is there another adjustment elsewhere for the water or is it just the valve?
#23 Posted : Thursday, July 22, 2010 1:41:13 PM(UTC)
Quote:
...the ice won't dump after it freezes and it doesn't seem to have enough water in the tray...
Seems that there are two separate problems and the first problem is more important. What is the status of the green LED? If it's blinking, the ice maker has to be replaced.
The new ice maker has an adapter and can be used with different kind of plugs.
- The ice maker Part number: AP4345120
JERRY314
#24 Posted : Thursday, July 22, 2010 1:45:16 PM(UTC)
JERRY314
sometimes it blinks and sometimes it doesn't. Is there a problem with the valve or something else?
#25 Posted : Thursday, July 22, 2010 6:56:18 PM(UTC)
More likely the only problem is a bad ice maker.
#26 Posted : Friday, July 23, 2010 1:20:20 AM(UTC)
Good advice Gene, one hint was the fact that it is intermittant which happens with electronic devices; never saw an intermittant optics board.
Guest (7)
3 Pages<123
