justn1978
#1 Posted : Tuesday, July 20, 2010 1:01:48 PM(UTC)
justn1978
Several of the wires from the timer/ control unit, came loose while I was cleaning inside of the dryer. I was able to find locations for all but 1 wire, green wire. Pretty sure this is a ground wire, the end of this wire is grounded to the body,but, another wire runs out of that connection , back into the dryer itself, its also green. Also has a different type of end on it, looks similar to the ends of all other wires that run into the timer, but , a little larger in size. Thanks
#2 Posted : Tuesday, July 20, 2010 3:26:44 PM(UTC)
Here is the Wiring diagram.
I did not see any ground terminals on the timer picture:
UserPostedImage
justn1978
#3 Posted : Tuesday, July 20, 2010 7:13:48 PM(UTC)
justn1978
Thanks Gene, I was unable to find that anywhere. Guess looking in wrong place. The wire I was talking about was green, its listed on the diagram as a ground wire, and is to be grounded on the chasis in 3 different locations. Appereciate the diagram, it solved the problem.Thanks
Guest (4)
timer wiring (Dryer Repair)
by richardbecker 9/21/2014 6:34:47 AM(UTC)
Timer Wiring (Dryer Repair)
by Rob NY 2/19/2014 10:54:05 AM(UTC)
Dryer Timer Wiring Schematics (Dryer Repair)
by DVO1978 12/13/2013 11:31:20 AM(UTC)
Maytag Timer Wiring (Dryer Repair)
by Big Boy 1/22/2013 9:31:40 AM(UTC)
Defrost Timer Wiring (Refrigerator & Freezer Repair)
by Will D 5/30/2012 3:44:58 PM(UTC)
483212 defrost timer wiring (Refrigerator & Freezer Repair)
by silverbay 11/5/2011 12:41:05 PM(UTC)
Whirlpool timer wiring change? (Washer Repair)
by patbob 10/17/2011 2:51:12 PM(UTC)
Timer Wiring Diagram (Dryer Repair)
by jmalone34 2/7/2011 10:05:40 AM(UTC)
timer wiring problems (Washer Repair)
by juteck 11/28/2010 7:15:59 AM(UTC)
GE DBXR453ET3WW timer wiring help (Dryer Repair)
by Snowboarder81 12/16/2009 12:57:46 AM(UTC)
Whirlpool Dryer Timer Wiring (Dryer Repair)
by leeke02 9/11/2009 4:09:39 AM(UTC)
Timer wiring (Dryer Repair)
by novelistwendy 2/3/2008 3:25:38 PM(UTC)
