cheryl54
#1 Posted : Thursday, July 15, 2010 1:21:59 PM(UTC)
cheryl54
Just replaced water level switch on Whirpool washer (LSR8233JQ0) and that works fine now. But the timer worked fine before I replaced the water level switch and now it just hums after the washer is filled with water. Is it possible that a connection got loose for the timer while getting the old water level switch out and the new one in? What do you think guys? Thanks.
#2 Posted : Thursday, July 15, 2010 4:14:20 PM(UTC)
Originally Posted by: cheryl54 Go to Quoted Post
...Is it possible that a connection got loose for the timer while getting the old water level switch out and the new one in?...
Everything is possible. Just open the control panel and double check all connections. :)
Washer stopping midcycle - Timer issue? (Washer Repair)
by stubarnes4prez 7/4/2014 5:51:33 PM(UTC)
Is this a timer issue? (Washer Repair)
by aultmans 9/19/2012 6:42:52 AM(UTC)
Spin Cycle won't end - Timer Issue? (Washer Repair)
by joefish 7/3/2012 7:39:00 AM(UTC)
Timer Issue? (Dishwasher Repair)
by raabe 6/21/2012 8:31:07 PM(UTC)
Timer Issue?? (Dryer Repair)
by sluggo 1/6/2011 12:06:22 PM(UTC)
by bw1 5/17/2010 7:12:07 AM(UTC)
Does this sound like a timer issue? (Washer Repair)
by nullstadt 5/14/2010 9:03:44 AM(UTC)
Possible timer issue? (Washer Repair)
by plow509 1/18/2010 6:53:55 PM(UTC)
timer issue?? (Washer Repair)
by ldutton 10/16/2009 8:09:22 AM(UTC)
Timer issue? (Dishwasher Repair)
by Chriskall 9/16/2009 11:37:04 AM(UTC)
