bw1
#1 Posted : Monday, May 17, 2010 7:12:07 AM(UTC)
bw1
GE - WJSR2080T5WW
The Machine never finishs the cycle. Always stops at "soak". I have to manually advance the timer pass the "soak". Do you think this is timer issue?
Sincerely,
BW
#2 Posted : Monday, May 17, 2010 7:44:14 AM(UTC)
You will need a voltmeter to confirm a bad timer. Does it fail in other cycles also, or just one? During this cycle, the timer sends voltage to the water solenoids to let water in, then the water level switch sends voltage to the motor to start agitating once it fills up. You may have other problems, these timers are usually pretty reliable.
Washer stopping midcycle - Timer issue? (Washer Repair)
by stubarnes4prez 7/4/2014 5:51:33 PM(UTC)
Is this a timer issue? (Washer Repair)
by aultmans 9/19/2012 6:42:52 AM(UTC)
Spin Cycle won't end - Timer Issue? (Washer Repair)
by joefish 7/3/2012 7:39:00 AM(UTC)
Timer Issue? (Dishwasher Repair)
by raabe 6/21/2012 8:31:07 PM(UTC)
Timer Issue?? (Dryer Repair)
by sluggo 1/6/2011 12:06:22 PM(UTC)
by cheryl54 7/15/2010 1:21:59 PM(UTC)
Does this sound like a timer issue? (Washer Repair)
by nullstadt 5/14/2010 9:03:44 AM(UTC)
Possible timer issue? (Washer Repair)
by plow509 1/18/2010 6:53:55 PM(UTC)
timer issue?? (Washer Repair)
by ldutton 10/16/2009 8:09:22 AM(UTC)
Timer issue? (Dishwasher Repair)
by Chriskall 9/16/2009 11:37:04 AM(UTC)
