Rob12312324
#1 Posted : Wednesday, July 14, 2010 11:26:49 AM(UTC)
Rob12312324
The refridge just stoped working. (not getting cold) where should I start looking for the problem?
#2 Posted : Wednesday, July 14, 2010 2:04:57 PM(UTC)
Does the compressor work?
How hot is the compressor on touch?
Does the fan motor next to the compressor work?
Does the condenser clean?
Does the fan motor inside the freezer work?
Can you see a frost build-up on the rear panel in the freezer?
The model number you posted is incomplete. Verify and repost it, please.
Rob12312324
#3 Posted : Wednesday, July 14, 2010 4:15:14 PM(UTC)
Rob12312324
Thank you Gene for getting back to me. The only thing that works is the light bulb. Model # ET18XKXRNR4
#4 Posted : Wednesday, July 14, 2010 5:56:49 PM(UTC)
In what positions are the both temperature controls?
Rob12312324
#5 Posted : Thursday, July 15, 2010 2:20:15 AM(UTC)
Rob12312324
I shut off both temp controls, and then turned them both back on to the highest setting. to no avail.
#6 Posted : Friday, July 16, 2010 8:06:04 PM(UTC)
Did you turn them off and on the same time?
You have to wait at least 10-15 minutes to turn it on again. Otherwise it can damage the compressor.
Both temperature controls set to the highest settings will make the freezer cold and the refrigerator warm.
