Receiving a F code at the beginning of the cycle. Seems to be filling and pumping fine. Any suggestions?
THIS FORUM IS DEAD!!!!!!! |
Denman,
You were right. It is an F50 error code. In your experience should replacement of RPS sensor fix this?
Yes it could be the sensor just run the tests in the tech sheet to try and conrm this.
Also check that the connections/wires are OK. |
Denman,
Ran diagnostic tests, and it seemed to point to the RPS sensor. I replaced that and the wiring harness, but still getting the code. Would you recommend control board replacement or motor replacement?
Thanks so much for your help!
Replacing the motor control board fixed the issue.
