bdbbrown
#1 Posted : Wednesday, July 7, 2010 4:58:53 PM(UTC)
bdbbrown
Receiving a F code at the beginning of the cycle. Seems to be filling and pumping fine. Any suggestions?
#2 Posted : Thursday, July 8, 2010 4:32:51 AM(UTC)
bdbbrown
#3 Posted : Saturday, July 10, 2010 10:20:19 AM(UTC)
bdbbrown
Denman,
You were right. It is an F50 error code. In your experience should replacement of RPS sensor fix this?
#4 Posted : Saturday, July 10, 2010 1:20:23 PM(UTC)
Yes it could be the sensor just run the tests in the tech sheet to try and conrm this.
Also check that the connections/wires are OK.
bdbbrown
#5 Posted : Monday, July 12, 2010 8:22:23 AM(UTC)
bdbbrown
Denman,
Ran diagnostic tests, and it seemed to point to the RPS sensor. I replaced that and the wiring harness, but still getting the code. Would you recommend control board replacement or motor replacement?
Thanks so much for your help!
bdbbrown
#6 Posted : Wednesday, July 14, 2010 7:33:15 AM(UTC)
bdbbrown
Replacing the motor control board fixed the issue.
