gcolonius@comcast.net
#1 Posted : Tuesday, July 13, 2010 6:59:11 AM(UTC)
We had a power loss/surge? yesterday, with flickering lights and now the dishwasher won't work. The buttons don't respond. Powering off gets the display to say PF or soil sensing, but it will still not respond to reset or work. Did the main board get fried? Is it worth fixing on my rather aged machine?
Estam
#2 Posted : Wednesday, May 15, 2013 6:32:31 AM(UTC)
Estam
Same problem few years ago and it just could be the fuse but in my case if the voltage fluctuated too much and there is a 115v to 12volt transformer that powers the control panel, it will short out with a large voltage fluctuation or lightening and will need replacement. Mine sat on the circuit board and once accessed can be checked with a voltage checker quite easily. Some basic knowledge of dis-assembly and voltage checking is necessary but it beats having to buy a new dishwasher. Best regards.
Simon / APP Team
#3 Posted : Wednesday, May 15, 2013 9:02:52 AM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
Most likely it is the control board. This part is no longer available. You should remove the control and check all soldering points at the back. Repair any burnt connection and you may get lucky.
Also disconnect the touch pad (membrane switch)flex ribbon from the control board, clean the edge with isopropyl alcohol and reconnect it back.
If all this doesn't help you will have a choice: manual dish washing or the new machine. :)
Good luck.
Simon.
Estam
#4 Posted : Thursday, May 16, 2013 6:41:16 AM(UTC)
Estam
Hi Simon, Do all this after he has checked for power to the board?
Dave...
Simon / APP Team
#5 Posted : Thursday, May 16, 2013 11:49:14 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I asume there is power to the control board because the display is on.
Simon.
Estam
#6 Posted : Friday, May 17, 2013 6:30:12 PM(UTC)
Estam
Thanks Simon, Yes, I read this post too quickly and missed that the led's where displaying pf so the cp must be getting some kind of power. Good luck to the op and maybe find a cp on ******** or something. .... Dave
Guest
#7 Posted : Wednesday, May 17, 2023 7:48:52 PM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
Hi I recently bought a new ge stacked washer and dryer.I have a4 prong electrical outlet the unit requires a 3prong I went back to Lowes and asked the salesman what to do to rectify this.. He said it was easier to change the cord than the unit. He gave me a cord and a friend that knows electronic s installed the cord. Washer is working however dryer is not. Would like to know what went wrong. Thanks Mark.
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Dishwasher Model GDT655SSJ2SS (Dishwasher Repair)
by Dan Jones 11/16/2023 11:33:43 AM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE dishwasher GDT580SSF5SS water doesn't get hot and dishes are not drying (Dishwasher Repair)
by jmbuffy 5/15/2023 4:45:57 PM(UTC)
GE Dishwasher Loads water but never agitates to clean dishes (Dishwasher Repair)
by Guest 4/19/2023 6:38:21 AM(UTC)
GE Dishwasher, Model: GDF530PGM0WW (Dishwasher Repair)
by Guest 4/12/2023 12:06:40 PM(UTC)
GE Dishwasher GSD900D-02 Door Gasket Gap (Dishwasher Repair)
by DJW000 2/5/2023 10:05:34 AM(UTC)
GE Dishwasher dead UI board (Dishwasher Repair)
by Guest 1/26/2023 9:44:03 PM(UTC)
GE dishwasher - general query about a ball at the back in the tube (Dishwasher Repair)
by delboy1881 7/27/2022 7:49:15 AM(UTC)
GE Dishwasher beeps every 10 seconds (Dishwasher Repair)
by bethH 7/12/2022 3:03:53 AM(UTC)
Ge dishwasher seal replacement (Dishwasher Repair)
by Guest 4/21/2022 5:34:16 AM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
