manualplease
#1 Posted : Sunday, July 11, 2010 12:46:53 PM(UTC)
manualplease
:([FONT="Comic Sans MS"][FONT="Tahoma"] i HOPE SOMEONE CAN HELP ME! I can't replace this and my husband has just said "I lost my job--do you think I am going to replace this? NO.Deal with washing dishes, Babe" and walked off. What can I do? My Quiet partner 2-about 2-1/2 years old does not work. I loaded it up as usual and hit normal--well, it started flashing-I hit cancel and it's flashing. I started to hit all of the buttons-so the cancel, normal and pots and pans all flash. The normal and pots and pans flash together. I threw the main breaker and it looked all normal...but then I pressed the normal button and it started it all over again!!did the same-same buttons flashing and it does not work. The horror set in--oh no-MY DISHWASHER IS BROKEN!!! Went to research on the internet (of course th one thing I want to do on my only day off ) and I pressed buttons together to reset-nothing. Just flashing-no working.I threw the breaker again...I pressed all of the buttons and the normal, pots and pans and cancel button started flashing again and the dishwasher does not work. just flashes. None of the buttons respond to anything. I am devastated. I can't replace this and it will make family meals more complicated for me after I have worked 10 hours a day! Please help if you can!!! Thank-you Angelique[/FONT][/FONT]
Brevard Appliance Repair
#2 Posted : Sunday, July 11, 2010 1:43:09 PM(UTC)
Groups: Expert
Sounds like your control may be bad.....it's easy to replace but can be costly...sorry
manualplease
#3 Posted : Sunday, July 11, 2010 2:23:03 PM(UTC)
manualplease
Sigh! Just what I suspected. Do you know how much those panels cost? Can I get one and put one in?
#4 Posted : Sunday, July 11, 2010 5:03:13 PM(UTC)
Groups: Expert
Sometimes depending on the shape of the dishwasher it could be better just to buy a new one. They go from $100 and upmost the time around $150. It is easy to put in, you should be able to do so...good luck
