2 Pages12>
RonOh
#1 Posted : Monday, September 10, 2007 2:21:56 PM(UTC)
RonOh
I have removed the old garbage disposer and now cannot remove the top flange that is in the sink. It is labeled as an "in sink-erator GE disposer". It looks as if it is part of the sink. Can you help?
RonOh
#2 Posted : Monday, September 10, 2007 3:05:26 PM(UTC)
RonOh
Thanks to this forum I figured it out on my own! I looked at the other post about disposal removal and saw the diagram there that was exactly the same as mine. THANK YOU!!! For those wanting to know.... there is a split ring on the pipe that fits in the top of the sink. It is hidden by the flange that has the tightening bolts that scew upward. This flange has a turned down edge to it that covers the splity ring that is actually below it, so just slide it up and expose the split ring and pry it off with a screwdriver. It really was simple once you had the diagram to look at!
:D
Admin / APP Team
#3 Posted : Tuesday, September 11, 2007 4:53:37 PM(UTC)
Admin / APP Team
Rank: Administration
Great job! Glad we could help...
Vinski
#4 Posted : Saturday, December 15, 2007 11:00:39 PM(UTC)
Vinski
:D
Somebody anybody - tell me where to get the diagram RonOh is talking about. I need to remove my insinkerator. Check these symptoms out -
1. It hums but turns freely (it is not stuck).
2. If you manually spin it with the power on, it will start working.
3. When you turn the power off, it will not start again unless you manualy spin it up to speed.
any comments welcome - but I am thinking I could remove the disposal, take it apart and find something inside like the piece of that old dishrag that got caught in there a week ago.
kawfeeman
#5 Posted : Sunday, December 16, 2007 9:07:32 AM(UTC)
kawfeeman
check warranty on your unit, but your start winding circuit is NG ( could be a start cap.. ) better to replace with a new unit ..
Vinski
#6 Posted : Monday, December 17, 2007 8:26:22 PM(UTC)
Vinski
Sounds right to me, now that you've explained it. It is probably the starter winding that has burned out and not a failing cap since the power was left on until the breaker tripped more than once. Still, since caps are cheaper...
Tho it's still not working, it still feels better knowing why.
thx again
twinsmom930@bellsouth.net
#7 Posted : Monday, June 9, 2008 6:42:13 PM(UTC)
Please give info on how to remove in sink erator that Ronoh (above) asked for an fouind a digram..I need it quick.......
#8 Posted : Monday, June 9, 2008 6:43:39 PM(UTC)
i need to know where you got your info for removal
mukinduri
#9 Posted : Friday, September 12, 2008 5:55:37 AM(UTC)
mukinduri
I found on the web the following manual for removal and installation of In_Sink-Erator.
www.insinkerator.com/pdf/US_ICU1.pdf
In my previous post I expressed confusion about a snap ring. My error. The manual makes it all clear.
rwomer
#10 Posted : Tuesday, November 6, 2012 7:48:20 AM(UTC)
rwomer
YAY Helped me too
2 Pages12>
