Door was locked, and now will not unlock. The lever goes back & forth, but something won't release. I suspect it has something to do with the cleaning cycle. Unfortunately, that functionality has been bad for years. The entire Clock unit and board has been bad for years. From the side, I can see, and reach the latch metal with a rod (where it enters the door), but pushing up/down/left/right does no good. Any thoughts?
Thanks!
Matt
I have the same. What d o you recommend? Originally Posted by: mmccoy3636  Door was locked, and now will not unlock. The lever goes back & forth, but something won't release. I suspect it has something to do with the cleaning cycle. Unfortunately, that functionality has been bad for years. The entire Clock unit and board has been bad for years. From the side, I can see, and reach the latch metal with a rod (where it enters the door), but pushing up/down/left/right does no good. Any thoughts?
Thanks!
Matt
