Pheasant Hollow Farm
#1 Posted : Wednesday, July 7, 2010 9:32:49 AM(UTC)
I have a Maytag MTF2455DR that was purchased in May of 2000. In the summer of 2004, I started to notice water leakage from the Freezer to behind the Insulation damper when the unit goes on the defrost cycle.
The water runs down the back wall of the refrigerator and pools on the bottom of the fresh food draws.
What can be done with this so that it drains into the housing control area where it is suppose to drain and then exit out the back?
I have given up on Sears Authorized Maytag repair personnel as well as any other Maytag repair people since they keep telling me that there isn’t anything wrong or they can't do anything about it.
Just put me in the right direction so I can fix this problem on my own. I am tired of paying for services not rendered.
There are no clogs in any drain lines, no cracks in any plastic.
Thanks in advance.
#2 Posted : Wednesday, July 7, 2010 1:41:58 PM(UTC)
Remove the rear panel in the freezer and check the drain hole in the drip tray under the evaporator. Very likely it's clogged and/or frozen up.
You can us a hair dryer to defrost it and run some hot water through it to make sure it is open.
Here are the breakdown diagrams and Freezer compartment replacement parts for MAYTAG MTF2455DRB Ref - Top Mount | AppliancePartsPros.com
#3 Posted : Wednesday, July 7, 2010 2:01:30 PM(UTC)
Gene,
I have had the back off and there is nothing clogged. The water is draining out and running down the backside of the fridge. It is missing the drain area in the housing control frame directly behind the insulation damper.
Steve
Pheasnt Hollow Farm
#4 Posted : Thursday, July 8, 2010 11:19:38 AM(UTC)
Steve,
Try to unscrew the front legs, so the refrigerator will tilt back a little.
#5 Posted : Thursday, July 8, 2010 11:38:27 AM(UTC)
Steve,
Gene,
It has rollers on the front and back, are these adjustable? As it is now, the fridge is level front to back and left to right. The door stays open in any position that it is placed in, no movement to either open wider or close.
Thanks for helping out... This is driving me crazy. I have had a bowl under this area for over 6 years now. I had a Sears Maytag service tech tell me it was the door gasket. I said okay, change it. It didn't have any cracks. He came back when the gasket arrived and replaced it and then siliconed the insulation damper to the upper part of the fridge(not to bright). I had to replace that whole unit since it was glued in place.
Do you know if there has ever been a recall on this model for this problem?
Again thanks for taking the time to help me out...
Steve
#6 Posted : Thursday, July 8, 2010 3:39:43 PM(UTC)
You are welcome Steve.
You can adjust them by following the instructions from the Owners guide (page 7).
#7 Posted : Thursday, July 8, 2010 3:56:50 PM(UTC)
Thanks Gene, I will check it out tomorrow.
Steve
#8 Posted : Tuesday, July 13, 2010 6:21:48 AM(UTC)
Steve
Gene,
Thank you for the suggestion on leaning the fridge. I do not believe this to be the true fix but only a remedy for the meantime. I have the fridge leaning forward almost a ¼ bubble off level. Leaning it back made more of the defrost water leaking down the back of the fridge panel and pooling more on the fridge compartment floor under the veggie crispers.
If and when a proper fix can be found, please email on the remedy. Having the door swing open is a royal pain.
Again thanks for the quick fix!
Steve
Guest (5)
