halfhandy
#1 Posted : Wednesday, July 7, 2010 9:40:04 AM(UTC)
halfhandy
My GE garbage disposal (GFC520F) is leaking from the gasket between the sink and the mounting ring. However, I have been unable to disconnect/remove the disposal from under the sink. Regardless of how much pressure I apply the disposal will not turn to release itself from the mounting ring it is locked to. Is there a trick to this? What am I doing wrong? Any suggestions?
Thanks.
#2 Posted : Wednesday, July 7, 2010 2:03:35 PM(UTC)
Hopefully the Installation instructions will help you.
halfhandy
#3 Posted : Wednesday, July 7, 2010 4:01:31 PM(UTC)
halfhandy
Thanks for the instruction manual. I actually have the original manual and instructions, and have read them. My problem is related to the disposal unit not coming free from the metal locking ring. When I attempt to turn the disposal the quarter turn counter clockwise the whole unit (disposal, mounting ring together) just turns. I cant seem to get the disposal to turn independently from the metal mounting ring. Is there a trick to this?
Thanks again
#4 Posted : Thursday, July 8, 2010 1:35:45 PM(UTC)
Originally Posted by: halfhandy Go to Quoted Post
...Is there a trick to this?...
Not really. Every time it happened, we have to find out some specific way out.
sarmentoc
#5 Posted : Sunday, June 26, 2011 2:07:58 PM(UTC)
sarmentoc
Thanks.
My disposal is just turning freely from the mounting ring, how can I make that quarter turn it is stuck?
gabage disposal removal (Garbage Disposer Repair)
by steve elliott 12/20/2010 4:00:36 PM(UTC)
