tippywanknobi
#1 Posted : Friday, July 2, 2010 1:00:24 PM(UTC)
tippywanknobi
whirlpool 25edrf will not cool unless unplugged for 5 mins. after 5 mins it will run a few days then i must unplug again.
#2 Posted : Friday, July 2, 2010 5:19:11 PM(UTC)
What does it do exactly before you have to unplug it?
The model number you posted is incomplete. Verify and repost it, please.
tippywanknobi
#3 Posted : Friday, July 2, 2010 5:29:07 PM(UTC)
tippywanknobi
gene the model number is ed25rfxfw01. the lights work on the frig and freezer but the circulation fan and the compressor fan and the compressor will not kick in unless i unplug the unit and let it rest . thank you for youer time !!
#4 Posted : Friday, July 2, 2010 5:44:18 PM(UTC)
Originally Posted by: tippywanknobi Go to Quoted Post
...the circulation fan and the compressor fan and the compressor will not kick in...
How long they were off before you had to unplug the unit?
Try to tap on the thermostat knob (the one on the right side) instead of unplugging the unit.
If everything will kick in, replace the thermostat (#9 on the diagram).
- The thermostat Part number: AP3037004
tippywanknobi
#5 Posted : Friday, July 2, 2010 5:55:17 PM(UTC)
tippywanknobi
thank you gene, thank you !!!! I tapped on the knob and presto it started right up !! Once again thank you for your time and effort !!! God bless and have a happy fourth of July !!!! Best regards Tippywanknobi
#6 Posted : Friday, July 2, 2010 8:34:00 PM(UTC)
You are welcome. Thank you for your good words. Happy 4th of July!
