skiplowflyin
#1 Posted : Thursday, June 5, 2008 6:01:42 AM(UTC)
skiplowflyin
My GE JB960 convection oven does not heat up properly in Bake. If I select Broil, the heating elements glow bright red. However, if I select bake the heating elements heat up to the touch but with no noticeable glow. In fact, it can't attain 300 degrees with out selecting broil or convection bake first. During the preheat on bake, a double click (sounds like some sort of cycling by a control) can be heard at regular cycles: 15 seconds between double clicks, followed by 70 seconds before the next double click. I have selected 430 as the desired temp. Convection bake was able to bring it up to temp, as was broil. Once at 430, I selected bake. It was unable to hold the temperature.
Any suggestions as to what I need to check/replace?
Thanks in advance!
skiplowflyin
#2 Posted : Thursday, June 5, 2008 6:54:57 AM(UTC)
skiplowflyin
OK, I think I narrowed it down. The bake controller relay is not working. And since I cannot solder well enough on my own, I guess the whole control board will have to be replaced unless anyone else has any good ideas...
F2 Error Code on GE Electric Oven (Oven Repair (including Ranges and Cooktops))
by Guest 9/11/2023 6:33:44 PM(UTC)
GE Electric Oven - Won't stay on (Oven Repair (including Ranges and Cooktops))
by tstwingirls@yahoo.com 2/23/2022 3:51:15 PM(UTC)
GE Electric Oven Won't Heat After Storm (Oven Repair (including Ranges and Cooktops))
by ccar45 11/22/2013 8:29:38 AM(UTC)
Ge electric oven wrong temp (Oven Repair (including Ranges and Cooktops))
by mmzullo 12/2/2012 10:42:56 AM(UTC)
GE electric oven issue (Oven Repair (including Ranges and Cooktops))
by BobChurch 8/26/2009 10:34:19 AM(UTC)
GE Electric Oven Broiler not working (Oven Repair (including Ranges and Cooktops))
by jmltoyo 11/23/2008 6:16:57 AM(UTC)
by Terry C 11/19/2007 8:49:14 AM(UTC)
