7 Pages«<23456>»
4mation
#31 Posted : Thursday, July 1, 2010 1:32:12 PM(UTC)
4mation
Hey Rich thanks for the reply i went ahead and installed the board like you said and the compressor came on instantly. The fridge seems to working fine now is there a reason the board failed? should i be checking anything else that might of caused this board to go bad, or was it just the boards time to quit?
#32 Posted : Thursday, July 1, 2010 2:48:19 PM(UTC)
It would help to put a 1000joule surge protector on the wall outlet, get one at Wall Mart designed for appliances
chrison600
#33 Posted : Wednesday, April 18, 2012 12:49:25 PM(UTC)
chrison600
Hi there,
I used this thread to diagnose and attempt a repair on my KitchenAid refrigerator (Model KSBS25INSS01). Based on the fact that I got a voltage reading at the fan connector, I ordered a fan (also from this site, Order # 2524374). Got the fan installed today. When I refit the connector, the fan spun for about 1 second, then quit. I unplugged the fridge, let it sit for about 10 seconds, then replugged. No fan, even when the compressor is running. The door frame is now getting hot again.
Circuit board?
Chris
#34 Posted : Wednesday, April 18, 2012 11:59:27 PM(UTC)
Seems like a bad control board AP3773712 located behind the control panel.
chrison600
#35 Posted : Thursday, April 19, 2012 6:43:38 AM(UTC)
chrison600
So the "control board" is not the actual board with membrane buttons and LED readouts, but another behind that board?
Chris
chrison600
#36 Posted : Friday, April 20, 2012 2:42:21 PM(UTC)
chrison600
Hello? Just looking for confirmation on the control board to order.
Thanks,
Chris
chrison600
#37 Posted : Friday, April 20, 2012 3:04:36 PM(UTC)
chrison600
Never mind. I took down the control panel so I could see the control board. I've just ordered one.
Chris
chrison600
#38 Posted : Thursday, April 26, 2012 12:21:04 PM(UTC)
chrison600
I installed the new control board yesterday afternoon. After plugging the fridge back in, when the compressor kicked on, so did the fan. Good.
Today the fan quit running again, so basically my new fan + new board got me through about 24 hours.
Is there something else to look at? Did I get a bad board?
Chris
#39 Posted : Friday, April 27, 2012 12:29:39 AM(UTC)
Yoy have another control board near the compressor AP4411082 Generally if it has a power relay on the board, it controls the compressor and condensing fan. You can check the schematic to find which board sends power to the condensing motor.
chrison600
#40 Posted : Friday, April 27, 2012 6:34:41 AM(UTC)
chrison600
Ok, so I'm sitting behind the fridge, taking off the back cover of the compressor control panel unit and I notice the condenser fan randomly turning on and off. While the compressor is running, the fan seems to just randomly turn on, run for a few seconds, then turn off.
Still the 2nd control board down at the compressor?
Chris
Guest (11)
7 Pages«<23456>»
