My ice maker does not seem to be filling with ice. Normally you can hear the water running into it, but not lately. It looked like a little water had run into it and stopped. Then the arm never rotated it out. My husband took it apart and said it looked like a little piece of ice was stuck, he then freed it and since nothing else has happened. Any help would be greatly appreciated. THANK YOU
add water with a cup directly into the cube compartment. If it works for that load it is either a stopped up supply line or there is no water getting to the ice tray.
Hi Gene, I just now got your message. I tried what Owen said with putting the water in and seeing if it would freeze and rotate the ice out and it did not. After that I was just going to go buy another ice maker.
Thank you both for your input.
Just in case, the part number for the ice maker is AP2984633Keep us posted. Gene.
