woodkutz
#1 Posted : Tuesday, June 29, 2010 8:34:04 PM(UTC)
woodkutz
While The Washer Is Off But Still Plugged In, The Drum Will Overfill With Clean Water All By Itself. I Can Spin The Water Out And Look Inside Hours Later And There Will Be More Water, Maybe Just A Little Or Maybe Alot. If Left Alone It Will Eventually Over Fill. Has Done This Twice In The Last Few Days. No Error Codes Showing.
sidfink43
#2 Posted : Friday, July 2, 2010 6:33:16 AM(UTC)
sidfink43
Sounds like your water valve assembly is stuck and needs replacing. Call APP with your model and serial number to get the right part as there are several of these for your model.
woodkutz
#3 Posted : Friday, July 2, 2010 8:19:15 AM(UTC)
woodkutz
Thanks for your help!!
Maytag Front Loading washer making noise (Washer Repair)
by joefigg1 5/22/2023 2:33:53 PM(UTC)
Maytag front loading washer (Washer Repair)
by Guest 4/23/2023 1:47:52 PM(UTC)
Maytag front load won't stop draining and is locked (Washer Repair)
by Guest 2/5/2023 1:32:02 PM(UTC)
Maytag front load med5630 electric (Dryer Repair)
by Guest 6/18/2022 11:44:28 AM(UTC)
maytag front loader washer model# mhwe300vf00 (Washer Repair)
by Guest 9/26/2021 9:57:51 AM(UTC)
Maytag Front Load Washer Model MHW8000AW0 (Washer Repair)
by Lery 4/8/2021 8:31:13 PM(UTC)
MHWE550WJ01 Maytag Front Load Washer No Water (Washer Repair)
by alligatorous 7/27/2020 11:07:06 PM(UTC)
Maytag front load (Washer Repair)
by Tfowler465 2/28/2017 1:56:52 PM(UTC)
Maytag Front Loader not dispensing bleach or fabric softner (Washer Repair)
by Ron1404 12/18/2016 3:42:55 PM(UTC)
Maytag Front Loader FH (Washer Repair)
by MyNameIsNate 8/2/2016 2:09:50 PM(UTC)
Maytag Front Load Washer Leaking During Spin Cycle (Washer Repair)
by michelleyeo 12/11/2015 9:34:09 AM(UTC)
Maytag front loader washer will not extract water from clothes all the time (Washer Repair)
by jsegura525 1/1/2015 7:48:41 AM(UTC)
UNBALANCED load - Maytag front loader MAH7500AWW (Washer Repair)
by mrogge 10/1/2014 7:40:59 AM(UTC)
Maytag Front Load Washer (Washer Repair)
by dengchr 2/5/2014 7:24:25 AM(UTC)
Maytag front loader 2000 series problem (Washer Repair)
by amarilloscout 10/11/2013 7:16:35 PM(UTC)
