Lery
#1 Posted : Thursday, April 8, 2021 8:31:13 PM(UTC)
Lery
I have a seven year old Maytag Front Load Washer Model MHW8000AW0. I was running a cleaning cycle and noticed that there was some water leaking on the floor. I checked all the connections and drain, and they're fine. Nothing wet by the connectors. I'm looking for some guidance on where to start troubleshooting this thing? I did a few searches and found it could be a few things. I'm hoping for some guidance on how I might go about taking it apart, and then I assume I will need to run it again to see where the water might be coming from.
The water does drain out and everything seems to function as normal, but obviously the water on the floor is not normal.
Edited by user Thursday, April 8, 2021 8:32:06 PM(UTC)  | Reason: Not specified
Lery
#2 Posted : Sunday, April 25, 2021 8:29:09 AM(UTC)
Lery
As an update, the leaking only happens during the cleaning cycle. I use the AFresh cleaning tablets and at about 25 minutes left, the leak starts. There is no leak during normal cycles.
Any advice or tips on this would be greatly appreciated.
