JAH
#1 Posted : Tuesday, June 29, 2010 12:54:12 PM(UTC)
JAH
Groups ready for retrieval: Registered
I noticed my refrigerator was decreasing in temperature gradually and then my freezer started warming up too. I shut down my refrigerator and defrosted it completely after noticing a solid build up of ice on the freezer coils. I've turned the refrigertor back on and the same thing is occuring 4 weeks later.
Any ideas?
#2 Posted : Wednesday, June 30, 2010 11:49:20 AM(UTC)
Replacement parts for JENN-AIR JCD2389DES Ref - SXS/I&W | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag_library/docs/16010154.pdf
See Page 2-15 on how to force a defrost cycle.
You have an adaptive defrost board, Item 13 in Section 2 of the parts.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle, the fans and compressor will turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the board needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 240Kohms ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
