Model #AAV7000ANN Ser # 27139118JL just replaced motor pulley and belt. Now it is not spinning as fast as before, clothes not dripping wet but too wet for dryer. pulley # 21001108 installed. Is this any way tied to the belt/pulley problem or just a coincidence? Noticed the top of agitator is almost independent of the bottom 1/2, can spin upper and the bottom does not. Is this normal? Seems the large pulley on bottom of drum is good, but as it goes up something is not working correct? Seems like something is slipping. Help please, or just say if more info is needed. thanks
If you did not replace the thrust bearing when you replaced the pulley, try that. Here is the part. Part number: AP4009132
