Cyprien
#1 Posted : Thursday, June 24, 2010 8:59:36 AM(UTC)
Cyprien
I called and asked to get the burner gasket , but they dont make it no more , said dont need it , so why do i have a flame at the base of the burner???????????/
#2 Posted : Thursday, June 24, 2010 12:44:55 PM(UTC)
Very likely the burner itself is bad. Remove it by unscrewing it CCW and inspect the burner and its orifice with the tube.
- The burner assembly Part number: AP4394705
Cyprien
#3 Posted : Thursday, June 24, 2010 2:54:22 PM(UTC)
Cyprien
I did Gene, all looks good , think i need the gasket that you cant buy no more???
#4 Posted : Thursday, June 24, 2010 3:37:45 PM(UTC)
This gasket has nothing to do with the gas leak. Thats why the manufacturer has discontinued this part. There is a leak somewhere in the gas supplying parts. You have to remove all burners and screws under the burners. Lift up the top panel and check all tubes.
Cyprien
#5 Posted : Friday, June 25, 2010 10:52:52 AM(UTC)
Cyprien
Gene ,
found the problem, i need the right front buner , its the power boost burner so how do i know which one to get.:)
#6 Posted : Friday, June 25, 2010 2:32:55 PM(UTC)
All burners for this model are the same. The difference in output made by a different orifices. You can use the part number I posted earlier.
