I called and asked to get the burner gasket , but they dont make it no more , said dont need it , so why do i have a flame at the base of the burner???????????/
Very likely the burner itself is bad. Remove it by unscrewing it CCW and inspect the burner and its orifice with the tube. - The burner assembly Part number: AP4394705
Originally Posted by: Gene  Very likely the burner itself is bad. Remove it by unscrewing it CCW and inspect the burner and its orifice with the tube. - The burner assembly Part number: AP4394705
I did Gene, all looks good , think i need the gasket that you cant buy no more???
This gasket has nothing to do with the gas leak. Thats why the manufacturer has discontinued this part. There is a leak somewhere in the gas supplying parts. You have to remove all burners and screws under the burners. Lift up the top panel and check all tubes.
Originally Posted by: Gene  This gasket has nothing to do with the gas leak. Thats why the manufacturer has discontinued this part. There is a leak somewhere in the gas supplying parts. You have to remove all burners and screws under the burners. Lift up the top panel and check all tubes.
Gene. Gene , found the problem, i need the right front buner , its the power boost burner so how do i know which one to get.:)
All burners for this model are the same. The difference in output made by a different orifices. You can use the part number I posted earlier.
