wranglersbaseball
#1 Posted : Tuesday, June 3, 2008 10:02:36 AM(UTC)
wranglersbaseball
I washed a sleeping bag the other day. It did not drain. I tried it again, and it would not spin. I emptied out the washer, and looked at the belt. I turned it a few times. I got washer to spin, but it was very noisy. I then tried to do a very small load, and it would not spin. It kept tripping out, and was very loud.
abadfish66
#2 Posted : Tuesday, June 3, 2008 10:15:55 AM(UTC)
abadfish66
Did your sleeping bag rip apart in the wash, if so the stuffing may be clogged in your drain pump
wranglersbaseball
#3 Posted : Tuesday, June 3, 2008 10:22:22 AM(UTC)
wranglersbaseball
No, it was fine. When I messed with the belt, and got it to run briefly, it was draining fine.
wranglersbaseball
#4 Posted : Tuesday, June 3, 2008 11:15:47 AM(UTC)
wranglersbaseball
The belt and pulley system seems to be very tight to turn.
wranglersbaseball
#5 Posted : Tuesday, June 3, 2008 11:41:08 AM(UTC)
wranglersbaseball
The sleeping bag was intact. It just will not spin. When I breifly get it to spin, it is veryloud, and may be smoking. Pully and belt are very tight, and hard to turn.
#6 Posted : Tuesday, June 3, 2008 1:44:01 PM(UTC)
Pull the belt off the trannt pulley and turn the pulley in the spin direction. If very hard to turn, you have something jamming the tub.Shine a lite in the tub to verify. You will need to pull the top off the tub and use a coat hanger to fish it out.
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Maytag MAV7600 will not spin a full wash load (Washer Repair)
by dfab 10/14/2022 11:13:21 AM(UTC)
Whirlpool Cabrio washer TWT8600 will not spin at the end of cycle (Washer Repair)
by ADK522JNRS 6/1/2022 5:53:35 AM(UTC)
Whirlpool LAT2500AAE Washer agitates one direction only and will not spin (Washer Repair)
by spmelick 3/21/2022 4:02:10 PM(UTC)
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
Cabrio will not spin or agitate (Washer Repair)
by Johneb06 1/19/2021 2:52:49 PM(UTC)
Kenmore Front Load Agitates, but will not spin (Washer Repair)
by krusen 1/2/2020 7:56:09 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Maytag MVWX655DW0 will not spin (Washer Repair)
by radams925 6/29/2019 9:50:29 AM(UTC)
Maytag A9200 Will Not Spin (Washer Repair)
by spirittoo 10/31/2018 1:58:04 PM(UTC)
GE no faults, will not spin on regular wash (Washer Repair)
by dekk_ks 3/28/2018 8:23:06 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
