2 Pages12>
jb2008
#1 Posted : Monday, March 31, 2008 4:26:30 PM(UTC)
jb2008
i have been experiencing problems with the fan and replaced with new one and still not working tested power coming out of harness and received correct reading now confused?
#2 Posted : Tuesday, April 1, 2008 4:19:19 PM(UTC)
What fan are you talking about - the evaporator fan or the condenser fan?
How did you test the power to the fan motor?
jb2008
#3 Posted : Thursday, April 3, 2008 5:56:19 PM(UTC)
jb2008
it's the evaporater fan which has a digital control board in the back of the fridge
#4 Posted : Friday, April 4, 2008 6:53:01 PM(UTC)
In most cases the evaporator fan motor has to be replaced together with the main control board.
- The part number for the main control board is AP3950129
Here are the break down diagrams for the GE refrigerator Model GTS22IBMARWW
tari
#5 Posted : Tuesday, June 3, 2008 9:03:40 AM(UTC)
tari
I need to remove and replace a fan from a GE freezer. Can you tell me how you removed the fan from the little pin holding it in place?
abadfish66
#6 Posted : Tuesday, June 3, 2008 9:13:45 AM(UTC)
abadfish66
Tari, do you have a model#
abadfish66
#7 Posted : Tuesday, June 3, 2008 9:20:46 AM(UTC)
abadfish66
Tari, I'm not sure I understand what pin your talking about. The fan is mounted to a bracket, that attaches to the plastic support orifice. you should be able to unscrew the motor mount from the plastic, remove it, and get access to the fan
tari
#8 Posted : Tuesday, June 3, 2008 9:29:57 AM(UTC)
tari
The little pin the fan spins on. I think the back side of the pin (deeper in the freezer closer to the wall) is then attached to the motor that spins it.
abadfish66
#9 Posted : Tuesday, June 3, 2008 9:47:15 AM(UTC)
abadfish66
You want to know how to replace the fan blade or the fan motor? If you just need to replace the blade, just pull it off the shaft
tari
#10 Posted : Tuesday, June 3, 2008 9:59:07 AM(UTC)
tari
I just need to replace the fan blade, not the motor. I can't get the blade off of the shaft. That is the problem.
GE profile fridge fan not working (Refrigerator & Freezer Repair)
by KevinM52 10/28/2013 4:12:19 PM(UTC)
by egonzales 6/10/2009 6:57:49 PM(UTC)
2 Pages12>
