michele1234
#1 Posted : 17 years ago
michele1234
i went out of town for a few days. came back went to do laundry and opened my front loader washer and water gushed out. it filled up by itself while i was gone. what you cause this? i have never heard of such a thing. please help
#2 Posted : 17 years ago
Most likely the water inlet valve stuck open. The solution is to replace the water inlet valve.
For more accurate advise and the right part number I need the complete model number of the washer.
michele1234
#3 Posted : 17 years ago
michele1234
it has not done it again can it be an intermitten problem
#4 Posted : 17 years ago
It could never come back, it could happen again next time you'll be out of town.
Well, if you want to try your luck...
lcramer8
#5 Posted : 16 years ago
lcramer8
I don't want to take a chance...I would like information on the part that will keep my unit from filling with water all the time. Mine does it all the time. My machine is a duet....Model number GHW9100LW2.....
woodchuckie
#6 Posted : 16 years ago
woodchuckie
inlet valve is where your water hoses hook. See part here Replacement parts for WHIRLPOOL GHW9100LW2 | AppliancePartsPros.com in the control panel diagram parts list.
rick c
#7 Posted : 16 years ago
rick c
I also have the same problem. I have a Kenmore Elite 110.44836301 . What part do I need. Thanks
woodchuckie
#8 Posted : 16 years ago
woodchuckie
Here's your water inlet valve to replace if yours is leaking. 110.44836200
harryoak
#9 Posted : 9 years ago
harryoak
Frigidare front-load washer Model 7088 FAFW3801LW
WHAT PART IS NEEDED?
