It fills with water and the dial moves through the cycles but it doesnt run.
Groups: Senior Expert, Administrators Joined: 7/19/2007(UTC) Views messages in topic : 27,455
Remove the bottom panel and check if the motor makes a humming noise when it should run. If it does, the pump & motor assembly has to be replaced. If it does not, check for 120 VAC at the motor plug and post the results. - The pump & motor assembly Part number: AP2616850
My dishwasher does not drain. Does it need the whole motor, that is a lot of money.
Originally Posted by: Ladytaz  My dishwasher does not drain. Does it need the whole motor, that is a lot of money. What is the complete model number of the dishwasher? Does the pump run during the drain? Gene.
Gene. The model #is GSD00X-66WA Ser#MM16971B Thank You very much
:) Originally Posted by: Ladytaz  It is very old, I think it is about 13yrs old. It was in the mobile home when we bought it. The mobile home was built in 97. The model #is GSD00X-66WA Ser#MM16971B Thank You very much
Originally Posted by: Gene  ...Does the pump run during the drain?... You did not answer this question. Gene.
Originally Posted by: Gene  You did not answer this question.
Gene. ooops sorry, not sure. I know that when I was using it the dishwasher did not drain at all. It would just overflow. We have tried taking the catch and cleaning it, making it free of gunk. Hope that answers your question somewhat. Thank You
I need you to remove the bottom panel, start the dishwasher and check if the motor will work or just will make a humming noise.
Originally Posted by: Gene  I need you to remove the bottom panel, start the dishwasher and check if the motor will work or just will make a humming noise.
Gene. Ok I will do that! I will have to do it the morning and let you know thanks
