jdslevi
#1 Posted : Thursday, June 17, 2010 6:43:42 PM(UTC)
jdslevi
It fills with water and the dial moves through the cycles but it doesnt run.
#2 Posted : Friday, June 18, 2010 2:10:49 PM(UTC)
Remove the bottom panel and check if the motor makes a humming noise when it should run.
If it does, the pump & motor assembly has to be replaced.
If it does not, check for 120 VAC at the motor plug and post the results.
- The pump & motor assembly Part number: AP2616850
Ladytaz
#3 Posted : Tuesday, June 22, 2010 5:17:29 PM(UTC)
Ladytaz
My dishwasher does not drain. Does it need the whole motor, that is a lot of money.
#4 Posted : Tuesday, June 22, 2010 7:35:27 PM(UTC)
What is the complete model number of the dishwasher?
Does the pump run during the drain?
Ladytaz
#5 Posted : Wednesday, June 23, 2010 6:39:33 AM(UTC)
Ladytaz
The model #is GSD00X-66WA Ser#MM16971B Thank You very much
Ladytaz
#6 Posted : Wednesday, June 23, 2010 6:42:43 AM(UTC)
Ladytaz
It is very old, I think it is about 13yrs old. It was in the mobile home when we bought it. The mobile home was built in 97. The model #is GSD00X-66WA Ser#MM16971B Thank You very much
#7 Posted : Wednesday, June 23, 2010 11:37:42 AM(UTC)
...Does the pump run during the drain?...
You did not answer this question.
Ladytaz
#8 Posted : Wednesday, June 23, 2010 11:59:32 AM(UTC)
Ladytaz
ooops sorry, not sure. I know that when I was using it the dishwasher did not drain at all. It would just overflow. We have tried taking the catch and cleaning it, making it free of gunk. Hope that answers your question somewhat.
Thank You
#9 Posted : Wednesday, June 23, 2010 12:52:51 PM(UTC)
I need you to remove the bottom panel, start the dishwasher and check if the motor will work or just will make a humming noise.
Ladytaz
#10 Posted : Wednesday, June 23, 2010 6:50:36 PM(UTC)
Ladytaz
Ok I will do that! I will have to do it the morning and let you know thanks
Guest (5)
