wesleymbrown
#1 Posted : Monday, June 2, 2008 4:30:10 PM(UTC)
wesleymbrown
Our refrigerator quit working. It is not an electrical problem (lights work, ice & water dispensers work, etc.). The serviceman that came & looked at it said that he thought the compressor was no good and that it could also be a board problem. He did not run any diagnostic tests on the compressor or the board. He advised us to buy a new unit, and we did that.
However, we would like to fix the old unit (it is otherwise in A+ condition) and use it. Is there a way to determine exactly what is wrong (or to get someone to do that) so that I can decide whether or not to repair the unit?
abadfish66
#2 Posted : Monday, June 2, 2008 4:35:38 PM(UTC)
abadfish66
When you say quit working, what exactly do you mean, symptoms? anything out of the ordinary that would give us a starting point
wesleymbrown
#3 Posted : Monday, June 2, 2008 10:26:08 PM(UTC)
wesleymbrown
We had been gone for a week. When we returned, the unit was warm and everything inside was thawed/melted. Because the smell wasn't very bad, we assume that the failure had occurred fairly recently - perhaps 2 or 3 days before. The unit was not making any noises - no hum, no clicks, nothing. Everything in the unit was working except the refrigeration, so it did not appear to be a general electrical problem. I unplugged, emptied and cleaned it, and left it to dry out overnight.
The next day I plugged it back in, but the situation had not changed. I called a local repairman in. He inspected the unit and told me that the compressor was bad. He also said that the circuit board could be bad, but that was a guess since he ran no diagnostics on it.
#4 Posted : Tuesday, June 3, 2008 1:39:42 AM(UTC)
Sounds like you have a adaptive pc board stuck in defrost, or a bad cold control.
Make some voltage tests to isolate the problem. Adaptive defrost board part # AP3214257
