jholovich
#1 Posted : 15 years ago
jholovich
I am not getting water in the dishwasher. I changed the fill valve, I am getting water to the valve, but no power. I changed the timer as well, but no voltage to the fill valve. The pump does run, so the door switch is working. I also checked the overflow switch, and that ohms out fine. Anyone got any ideas. The only thing left is to change the control switches.
#2 Posted : 15 years ago
Remove the inner door panel and check the pushbutton switches on the left side. Most likely one of them is broken or burned out.
- The pushbutton switch kit Part number: AP2617405
jholovich
#3 Posted : 15 years ago
jholovich
The Switch Was Bad For The Heated Dry On/off Option. Thankyou So Much For Your Help!!!
#4 Posted : 15 years ago
You are welcome. I'm glad you were able to fix it. Thank you for the feed back.
No Power to fill valve (Dishwasher Repair)
by dpk1000 17 years ago
