jholovich
#1 Posted : Monday, June 21, 2010 10:10:04 AM(UTC)
jholovich
I am not getting water in the dishwasher. I changed the fill valve, I am getting water to the valve, but no power. I changed the timer as well, but no voltage to the fill valve. The pump does run, so the door switch is working. I also checked the overflow switch, and that ohms out fine. Anyone got any ideas. The only thing left is to change the control switches.
#2 Posted : Monday, June 21, 2010 2:53:12 PM(UTC)
Remove the inner door panel and check the pushbutton switches on the left side. Most likely one of them is broken or burned out.
- The pushbutton switch kit Part number: AP2617405
jholovich
#3 Posted : Wednesday, June 23, 2010 12:19:21 AM(UTC)
jholovich
The Switch Was Bad For The Heated Dry On/off Option. Thankyou So Much For Your Help!!!
#4 Posted : Wednesday, June 23, 2010 11:04:37 AM(UTC)
You are welcome. I'm glad you were able to fix it. Thank you for the feed back.
Guest (5)
No Power to fill valve (Dishwasher Repair)
by dpk1000 9/12/2007 4:34:21 PM(UTC)
