Larry and Irene Rinne
#1 Posted : Tuesday, June 22, 2010 2:38:11 PM(UTC)
The fan motor quit working. So I removed the panel cover and by spinning the motor stem and then starting the dryer I got it to run. I was priming it so to speak. Is that what the capacitor is supposed to do?
sidfink43
#2 Posted : Friday, June 25, 2010 8:49:42 AM(UTC)
sidfink43
Hi Guys
Yes, that is what the capacitor is supposed to do, but it is rare that a capacitor fails. You can try replacing it, and if you purchase from this site and it does not fix things you may be able to return it for a refund. See the returns policy or talk with APP before you order it.
If the problem persists it may be that the motor itself is in the process of failing.
