expetrush
#1 Posted : Monday, June 21, 2010 10:15:48 AM(UTC)
expetrush
I have a Kenmore side by side where the water dispensor is not working. All selenoids are working fine becuase if I unhook hose @ coupling @ bottom of door/hinge & I use the water dispensor, water flows freely in a bucket. (water is not delivered to the door dispensor & can't even blow into it to clear any possible blockage. Is there another selonoid or check valve in the door?
My gues is there is a kinked hose or blockage somewhere in the freezer door. has anyone had this issue & maybe have a schematic to show me how to pull the door apart to resolve this?
Many thanks.
Kenmore Elite side by side
model # 253-44383409
#2 Posted : Monday, June 21, 2010 3:16:59 PM(UTC)
Sounds like the water line inside the freezer door is frozen. Make sure the temperature in the freezer is not bellow 0°F and the door was not kept open. The best way to fix it is to open the freezer door and keep it open for a few hours or until the water line is defrosted.
expetrush
#3 Posted : Monday, June 21, 2010 5:32:10 PM(UTC)
expetrush
This is our only refrig/freezer... do I have any other options? From the hinge at the bottom of the freeze door to the outlet, is there any other restrictions? (check valves, etc?) could I try to dethaw, melt any other way? I can not seem to find a schematic to see what is in the door.
#4 Posted : Tuesday, June 22, 2010 11:35:34 AM(UTC)
The door is not serviceable, so this is probably the only what can be done.
pinoy_ako
#5 Posted : Wednesday, June 23, 2010 8:17:21 PM(UTC)
pinoy_ako
You must set the temperature to lower. Or maybe it has a clogged drainage ito your despenser, use a wire to unclogg it.
May pilipino ba dito. I-pm nyo ako nang magkakilala tayo. Magtayo tayo ng samahan or grupo. Mag usap tayo sa internet. Or gumawa tayo ng forum na pang pinoy.
Refrigerator Water Dispensor not working (Refrigerator & Freezer Repair)
by aperkins187 2/6/2013 6:18:03 AM(UTC)
by Cali12b10 2/27/2012 11:43:16 AM(UTC)
Water dispensor not working on GE Profile (Refrigerator & Freezer Repair)
by millertcb 3/21/2011 12:24:43 PM(UTC)
water dispensor not working (Refrigerator & Freezer Repair)
by dan donaldson9 9/24/2010 11:01:18 AM(UTC)
automatic ice and water dispensor not working (Refrigerator & Freezer Repair)
by Colin Twedt 6/20/2009 8:08:53 PM(UTC)
