2 Pages12>
blieberman
#1 Posted : Monday, June 21, 2010 9:32:02 AM(UTC)
blieberman
Our icemaker stopped dispensing over the weekend. There is ice in the tray. In the past, this problem has been caused by an ice cube lodged in the "fingers" but not the case this time. Any solution other than replacing the unit? Is the icemaker easy to replace for the average homeowner?
Thnaks!
#2 Posted : Monday, June 21, 2010 2:38:32 PM(UTC)
I'm afraid I did not get it clear. It does not dispense ice through the door or it does not release ice cubes from the ice maker into the ice container?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRI25FNSS00 Refrigerator | AppliancePartsPros.com
blieberman
#3 Posted : Monday, June 21, 2010 2:58:19 PM(UTC)
blieberman
Hi Gene!
The ice maker is not sweeping the ice out of the ice maker into the hopper.
#4 Posted : Monday, June 21, 2010 4:41:38 PM(UTC)
Open the freezer door. Push in the flapper door on the left side and watch the status LED on the right side. Post the results.
blieberman
#5 Posted : Tuesday, June 22, 2010 6:00:20 AM(UTC)
blieberman
Gene,
The LED status light is not on in either position. Turned the switch off and back on and LED is still dark.
Bruce
#6 Posted : Tuesday, June 22, 2010 10:41:27 PM(UTC)
Bruce,
Looks like the problem is a bad optic PC boards.
- The PC boards kit Part number: AP3137510
blieberman
#7 Posted : Wednesday, June 23, 2010 4:46:52 AM(UTC)
blieberman
Thanks Gene! You're a real asset to this Board!
#8 Posted : Wednesday, June 23, 2010 11:11:54 AM(UTC)
Thank you for your good words. Keep us posted.
blieberman
#9 Posted : Friday, June 25, 2010 2:33:26 PM(UTC)
blieberman
Hi Gene,
New sensor did the same thing, no light w/ the flapper open or depressed. Put the old sensor back in. It will blink when I depress the light button @ the top to simulate the door being closed.
Bruce
blieberman
#10 Posted : Friday, June 25, 2010 3:04:30 PM(UTC)
blieberman
Now the old sensor blinks when door is open and steady on when flapper closed!
Guest (7)
2 Pages12>
