Replacement parts for WHIRLPOOL LER5636PQ0 29"electric Dryer | AppliancePartsPros.comHere is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdfNote: I do not work for AppliancePartsPros so if the below advice is no good blame me not them.
[COLOR="Blue"]
Installed new heating element and was still blowing cold air. [/COLOR]
How did you know that the heater was blown? Did you measure it with a meter? Was the heating coil broken? Or did you just think that it was the most likely cause?
[COLOR="Blue"]Stopped to look for info on manuels for whirpool dryer on different sites. No luck.[/COLOR]
Could not find a manual but did get the wiring diagram.
[COLOR="Blue"]I then went back to work on dryer and now dryer wont even start.[/COLOR]
You must have messed something up or forgot to reconnect something. The most likely would be the door switch.
You will notice that the motor and the heater circuits are pretty well separate in the unit.
The heater runs on 240 (L1 to L2)
The motor runs on 120 (L1 to Neutral)
[COLOR="Blue"]Was told by a friend that needed to reset relay. read that you couldnt reset.[/COLOR]
I have no idea what your friend was referring to, never heard of a reset relay on a dryer.
[COLOR="Blue"]Please tell me how to get dryer working properly after install of new heating element purchased by your company please.[/COLOR]
You will have to do some trouble shooting a meter will be very helpful here.
First check that the unit is getting the correct power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!! [/COLOR]
