amcburney
#1 Posted : Saturday, June 19, 2010 10:56:45 AM(UTC)
amcburney
Oven not heating up properly. Turned it on earlier today and it heated up to about 210 degrees (set for 350). Digital display and cook-top are all working. Broiler is working. Control keeps clicking and bottom stove element is not heating up at all now.
#2 Posted : Sunday, June 20, 2010 2:44:48 AM(UTC)
Replacement parts for MAYTAG MERH752BAW Range - S/c F/s Ele | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag_library/docs/16026784.pdf
And the tech sheet which may vary slightly from the manual
http://www.servicematters.com/maytag_library/docs/16026688.pdf
I am assuming the unit never comes ready.
Could be the bake element is shot.
Remove it and measure it with a meter, should be about 21 ohms.
Note: It is very important to unplug / remove power from the unit when doing this as one side of the element always has 120 volts on it even when turned Off.
Need help narrow down oven problem (Oven Repair (including Ranges and Cooktops))
by Guest 7/4/2022 6:46:54 PM(UTC)
Thermador PG304BS/09 Oven Problem (Oven Repair (including Ranges and Cooktops))
by Guest 8/15/2021 7:27:03 PM(UTC)
Range oven problems. (Oven Repair (including Ranges and Cooktops))
by jorge osorio 1/29/2019 1:16:21 PM(UTC)
Oven Problem - lower, no heat; upper A-OK (Oven Repair (including Ranges and Cooktops))
by gesche444 9/15/2017 12:21:36 PM(UTC)
Oven problem (Oven Repair (including Ranges and Cooktops))
by Lhodges 1/28/2017 10:58:04 PM(UTC)
Kitchen Aid oven problem (Oven Repair (including Ranges and Cooktops))
by Rawger11 9/2/2014 11:13:56 AM(UTC)
Maytab oven problem (Oven Repair (including Ranges and Cooktops))
by DJ5140 3/16/2014 8:43:29 AM(UTC)
Whirpool Oven Problems (Oven Repair (including Ranges and Cooktops))
by phsffaman 2/15/2014 6:35:40 PM(UTC)
Oven problem during self clean cycle (Oven Repair (including Ranges and Cooktops))
by cgoetzfried@att.net 1/21/2014 5:48:07 PM(UTC)
kitchenaid oven problem (Oven Repair (including Ranges and Cooktops))
by ticat900 11/25/2013 11:06:28 AM(UTC)
Range/oven Problem (Oven Repair (including Ranges and Cooktops))
by slongo 10/22/2013 5:06:51 AM(UTC)
GE Profile Oven Problems (Oven Repair (including Ranges and Cooktops))
by RSF 10/16/2013 10:23:15 PM(UTC)
by Whizknot 10/7/2013 7:31:01 PM(UTC)
self cleaning oven problem (Oven Repair (including Ranges and Cooktops))
by preachergirl09 9/8/2013 11:20:21 AM(UTC)
wall oven problems (Oven Repair (including Ranges and Cooktops))
by jethro75 8/1/2013 6:35:09 AM(UTC)
