howardmitchell7
#1 Posted : Friday, June 18, 2010 2:25:21 PM(UTC)
howardmitchell7
Groups ready for retrieval: Registered
Timer won't advance in auto mode, but will in timed mode. Replaced timer, same problem.
#2 Posted : Saturday, June 19, 2010 3:28:03 AM(UTC)
Replacement parts for General Electric DWXR473ET3WW Electric dryer | AppliancePartsPros.com
GE likes to keep their tech data a secret so I cannot find a wiring diagram specific to your unit.
The following though is probably close.
http://www.applianceaid.com/image/geediagram.JPG
Often the wiring diagram is either pasted to the back or in the control console.
The way it works is that when the heating coil is shut off by a thermostat the timer gets it's power through the coil. This is 240 volts so the resistor drops the voltage down to 120 volts which is required by the timer motor.
Unplug the unit
Check the resistor (Item 80 in Section 1), should be around 4000 ohms.
If OK
Remove the wires from the heating coils.
Mark them so you know where they go.
Check each coil for resistance, usually 15 to 20 ohms.
Then check them to the machine's frame/case.
All should be infinite ohms.
If not you have a grounded element, it has broken or sagged and is touching the case and is on all the time. The thermostat's cannot control it and since it does not shut off the timer never advances.
howardmitchell7
#3 Posted : Saturday, June 19, 2010 4:53:26 AM(UTC)
howardmitchell7
Thanks for the quick reply. If the timer does not advance in Fluff Air Dry mode, should that eleminate the heater coils as a potential problem and narrow it down to the resistor?
#4 Posted : Saturday, June 19, 2010 5:07:41 AM(UTC)
[COLOR="Blue"]If the timer does not advance in Fluff Air Dry mode, should that eleminate the heater coils as a potential problem and narrow it down to the resistor?[/COLOR]
Not really.
If you look at the wiring diagram, of course this assumes I got lucky and it is close to yours, the temperature selector switches should all be open so the timer motor would get power through the upper heating coil on the wiring diagram.
So in Fluff if there is any heat at all the element is grounded.
Also if the upper element is blown then you will not get any timer advance.
howardmitchell7
#5 Posted : Saturday, June 19, 2010 5:20:34 AM(UTC)
howardmitchell7
Got it. So is there a bulletin/manual that tells me how to access the heating elements?
#6 Posted : Saturday, June 19, 2010 6:17:20 AM(UTC)
No manuals etc that I know of perhaps the following will help.
http://www.applianceaid.com/dryers.html
GE likes to keep info a secret.
howardmitchell7
#7 Posted : Monday, June 21, 2010 7:03:48 AM(UTC)
howardmitchell7
I found a break in one of the elements. Can this be repaired, or do I need to replace the entire element?
#8 Posted : Monday, June 21, 2010 12:36:41 PM(UTC)
It cannot be fixed, you have to replace it.
Se Item 512 in Section six.
Note: That you can get the coil by itself and it is way cheaper, see below.
Part number: AP2620171
Since you have to take it all apart you may as well check the rear bearing, belt , front drum supports, etc. Basically do an overhaul.
Aklso a good time to clean/check your vent system.
Whirlpool Dryer - Timer Won't Advance in Auto (Dryer Repair)
by AMarkham40 12/10/2016 11:18:39 AM(UTC)
Timer won't advance in auto modes (Dryer Repair)
by sly1types 10/17/2011 2:29:33 PM(UTC)
GE dryer timer won't advance in auto mode (Dryer Repair)
by jwysocky 2/20/2010 10:28:06 AM(UTC)
