henry johnson
#1 Posted : Friday, June 18, 2010 7:31:42 AM(UTC)
henry johnson
Igniter fires continually. Previous problems have been corrected with unplugging the electrical plug, waiting for a couple of hours, then reconnecting. This time, the problem persists.
#2 Posted : Friday, June 18, 2010 11:06:09 AM(UTC)
Sounds like one of the ignition switches (#2 on the diagram) is shorted. The correction is to replace it. It comes as a switch/lead assembly.
- The switch/lead assembly Part number: AP4098005
Guest (4)
