AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
'Tapping' sound at each revolution of the drum
My Neptune dryer, although empty, makes a tapping sound at each revolution of the drum. The sound is like you would expect to hear if you were to tap the inside of the drum with the end of a leather belt. I would like to open the dryer to inspect around the drum, and it looks like you have to unlock the top lid somehow and simply lift the front of the lid and rotate it up and over, toward the back of the machine. Trick is, how do you "unlock" the top to do that without prying around with a screwdriver and breaking the white enamel to pieces? In advance ~ thanks!
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
