vikktorlv
#1 Posted : 15 years ago
vikktorlv
Hello,
My fridge and freezer seem to still be cold inside but the outside on the freezer side is Very warm to the touch. What would cause this. I took the back apart and cleaned the coils and everything, but the fan between the compressor and condensor doesn't seem to turn on, but I don't know at what point it should. Is there a sensor ,thermostat somewhere that should tell it when to turn on that might be bad, or is it built onto the fan unit
? Trying to repair myself if possible. Thank you.
Shawn
yupyupyup
#2 Posted : 15 years ago
yupyupyup
it really sucks there isn't an answer to this yet. I have the exact same problem and am afraid the house is going to burn down.
#3 Posted : 15 years ago
Often this is dirty condenser coils or the condenser fan is not running correct
