vikktorlv
#1 Posted : Wednesday, April 28, 2010 4:10:57 PM(UTC)
vikktorlv
Hello,
My fridge and freezer seem to still be cold inside but the outside on the freezer side is Very warm to the touch. What would cause this. I took the back apart and cleaned the coils and everything, but the fan between the compressor and condensor doesn't seem to turn on, but I don't know at what point it should. Is there a sensor ,thermostat somewhere that should tell it when to turn on that might be bad, or is it built onto the fan unit
? Trying to repair myself if possible. Thank you.
Shawn
yupyupyup
#2 Posted : Tuesday, June 15, 2010 8:25:46 PM(UTC)
yupyupyup
it really sucks there isn't an answer to this yet. I have the exact same problem and am afraid the house is going to burn down.
#3 Posted : Thursday, June 17, 2010 3:58:52 AM(UTC)
Often this is dirty condenser coils or the condenser fan is not running correct
