tmilano911
#1 Posted : Wednesday, June 16, 2010 4:11:46 PM(UTC)
tmilano911
Have a dryer that wont start.. trying to fix it and I took the back apart and saw that the push start looked to be fired....I ordered a new part and the new one has three spots for wirers and the old one only had two....do the three have to be connected????.....
#2 Posted : Thursday, June 17, 2010 2:22:48 AM(UTC)
[COLOR="Blue"]do the three have to be connected????.....[/COLOR]
No.
Your switch probably has one connector that is not near the other 2, this is usually the Common.
The other 2 will be a Normally Open (NO) and a Normally Closed (NC).
They are usually marked on the switch.
You want to connect to the Common and the Normally Open.
Dryer Wont Start...... (Dryer Repair)
by tmilano911 6/16/2010 10:59:06 AM(UTC)
