Water Does Not Shut Off When Entering Machine And Does Not Agitate. But Will Spin Out, Help
Does water enter when the machine is off or unplugged?
No. Just When I Pull Knob Out To Fill.
Originally Posted by: SYLVANIA  No. Just When I Pull Knob Out To Fill. NO.JUST WHEN I PULL OUT KNOB TO TURN ON
So if you turned it on a regular wash and walked away, it would overfill the tub? If that is the case it is going to be a problem with either the presure switch or the hose to the pressure switch. Do you use bleach regularly, also I need a model#...
No I Don't Use Bleach Too Often The Model# 41798702891
Because you don't use bleach regularly, I am suspecting that the end of the pressure switch hose is clogged where it connects to the tub... The model# you gave is not a model# for your machine, There will be a sticker with model# and serial#, usually if you open the lid it is there, maybe on the side panel of the machine
This Is The Part Number On Both Machine And Paperwork For My Kenmore Laundry Center. What Do I Do To Unstop This Hose End?? IS THIS ALSO WHY IT WON'T AGITATE? ANY HELP WOULD BE APPRECIATED,.
On the front bottom of the machine, there should be 2 screws at the bottom, you'll need to take that front cover off. the hose will be a small clear hose attached to a nipple on the outer tub. pull the hose off the tub and look for brown color at the end of the hose. let me know what you find
I will let you know ASAP waiting for my son to get home from work to do as you suggested. Thanks
