2 Pages12>
SYLVANIA
#1 Posted : Friday, May 30, 2008 7:12:06 AM(UTC)
SYLVANIA
Water Does Not Shut Off When Entering Machine And Does Not Agitate. But Will Spin Out,
Help
abadfish66
#2 Posted : Friday, May 30, 2008 7:18:33 AM(UTC)
abadfish66
Does water enter when the machine is off or unplugged?
SYLVANIA
#3 Posted : Friday, May 30, 2008 7:24:30 AM(UTC)
SYLVANIA
No. Just When I Pull Knob Out To Fill.
SYLVANIA
#4 Posted : Friday, May 30, 2008 7:26:43 AM(UTC)
SYLVANIA
NO.JUST WHEN I PULL OUT KNOB TO TURN ON
abadfish66
#5 Posted : Friday, May 30, 2008 7:37:25 AM(UTC)
abadfish66
So if you turned it on a regular wash and walked away, it would overfill the tub? If that is the case it is going to be a problem with either the presure switch or the hose to the pressure switch. Do you use bleach regularly, also I need a model#...
SYLVANIA
#6 Posted : Friday, May 30, 2008 7:46:41 AM(UTC)
SYLVANIA
No I Don't Use Bleach Too Often The Model# 41798702891
abadfish66
#7 Posted : Friday, May 30, 2008 8:10:47 AM(UTC)
abadfish66
Because you don't use bleach regularly, I am suspecting that the end of the pressure switch hose is clogged where it connects to the tub... The model# you gave is not a model# for your machine, There will be a sticker with model# and serial#, usually if you open the lid it is there, maybe on the side panel of the machine
SYLVANIA
#8 Posted : Friday, May 30, 2008 8:46:08 AM(UTC)
SYLVANIA
This Is The Part Number On Both Machine And Paperwork For My Kenmore Laundry Center.
What Do I Do To Unstop This Hose End??
IS THIS ALSO WHY IT WON'T AGITATE?
ANY HELP WOULD BE APPRECIATED,.
abadfish66
#9 Posted : Friday, May 30, 2008 8:53:48 AM(UTC)
abadfish66
On the front bottom of the machine, there should be 2 screws at the bottom, you'll need to take that front cover off. the hose will be a small clear hose attached to a nipple on the outer tub. pull the hose off the tub and look for brown color at the end of the hose. let me know what you find
SYLVANIA
#10 Posted : Saturday, May 31, 2008 5:00:11 AM(UTC)
SYLVANIA
I will let you know ASAP waiting for my son to get home from work to do as you suggested. Thanks
2 Pages12>
