AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
start/cancel button not working on maytag 100 series
All the other lights are working but the start/cancel button, which is unresponsive, so I can't run the machine. Will replacing the control panel and touch pad solve the problem?
Here are your parts Replacement parts for MAYTAG MDB5600AWW Dishwasher - Undercounter | AppliancePartsPros.comHere is the tech sheet http://www.servicematters.com/maytag_library/docs/16023063.pdfAnd a manual http://www.servicematters.com/maytag_library/docs/16021814.pdfThe usual way to trouble shoot this is to check the switches on the control panel (keypad) with a meter, see the tech switch. If OK then the control board is probably the problem You may want to try the following: Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try. |
THIS FORUM IS DEAD!!!!!!! |
Dishwasher Repair
