2 Pages<12
tomlao
#11 Posted : Friday, August 29, 2008 8:20:01 PM(UTC)
tomlao
I did some more checking and the power supply to the motor controller board is causing the problem. When I unplug it, all the lights come on.
Can you gives me the part number to the motor controller boards at the bottom of the machine?
libertyappl
#12 Posted : Saturday, August 30, 2008 6:51:57 AM(UTC)
libertyappl
The part number for the motor controller is AP3968010. Hope that gets you going.
Nat
tomlao
#13 Posted : Thursday, September 4, 2008 8:11:35 PM(UTC)
tomlao
Thanks Libertyappl. That does it. The washer is powering up but got a small problem. I misplaced the two screws for the door hinge so I can not test it out. Where can I get some?
**FOUND THEM*** WASHER IS WORKING AGAIN BUT I WOULDN"T BUY ANOTHER WHIRLPOOL WITH THE SUPPORT I DIDN"T GET FROM THEM!!
ralphien
#14 Posted : Sunday, February 15, 2009 3:04:42 AM(UTC)
ralphien
Originally Posted by: tomlao Go to Quoted Post
HELP!! I have a WFW9200SQ00 and it's DEAD! Nothing comes on except the lock button. When the power button is pressed, I hear three chimes.
I bought a control electic board (8183261), replaced it and still the same.
i have the exact same problem. tech came over friday(2/13) and said it was the MCC. 150.00 for the service call and 570.00 for the part.the washer is going to be 2years old on 3/29,so whirlpool is paying for the
part. i see that the same part can be bought here for 236. a nice markup, eh
Charlie75
#15 Posted : Monday, June 14, 2010 2:55:31 PM(UTC)
Charlie75
Originally Posted by: libertyappl Go to Quoted Post
Try running it thru diagnositc first, see if you get any error codes.
Execute this procedure with an empty drum. All of the steps
below must be done in sequence in order to reach the
Diagnostic test. This executes the automatic test only.
1.
Close the door.
2.
Push power.
3.
Select the “Drain and Spin” program.
4.
Deselect the rinse option (for Kenmore only).
5.
Select “No spin”.
6.
Push “Prewash” option four times within five seconds. If
Prewash is not present on this model, press “Extra Rinse”
7.
The automated test program is started (not possible to
skip steps).
8. To cancel the test program press the “Stop” button.
Post your results
Nat
Sorry if this is too old of a thread but I ran the diagnostic program on my machine. The display started with a C:01 and ended with an F20 with the 20 flashing. Can you please tell me what this error code is? Thanks
Charlie75
#16 Posted : Monday, June 14, 2010 3:24:51 PM(UTC)
Charlie75
1.
Close the door.
2.
Push power.
3.
4.
5.
Select “No spin”.
6.
7.
skip steps).
Post your results
Nat
Sorry, I guess I'm unable to enable the automatic test program. I see what the C:10 and F20 codes are which doesn't surprise me because it's sitting in my garage.
Guest (6)
2 Pages<12
